[SOLVED] Expo
Tgalo
Hi, finally got to try my Spirit on my Bell47. All went well except it was super sensitive. Id like to tone it down and was wondering the best way. Flight style is set to 4. Cyclic feed default. Can I add a bit of expo from the transmitter? Thanks, T
yes, you can use any expo value you want. Recommended value is around 25% for the beginning.
You can also increase Flight Style value to make it more smooth near the center and also to decrease Rotation Rate. This can help a lot.
Tgalo
Thank you, I will make adjustments.
T
