Return to Home - Field Programming
BenLeo
Geolink configuration instructions say that a new home position can be programmed at the field by placing switch in On(2). My configuration is setup correctly, confirmed by status message in Spirit Link.
However, when placing switch on On(2) the LED doed not turn off at all and a new home position has not been set. The swash plate does slowly rise and then after a moment, decends quickly.
Can someone please advise what I am doing wrong? I would like to be able to program a new home position at the field without a computer.
mentioned LED status is changing at the Spirit unit, not GeoLink.
Swashplate behavior is correct. Once it will finish the movement, new position is programmed.
BenLeo
Thank you. I see that now. I had convinced myself it was the geolink even after reading the instructions...
