Button in PC/Mac Software or JETI Setup
Posted: Tue 29. Sep 2020 22:04:06
by yamahahoyt
It would be helpful/nice to have a button in the servosetup (Swashplate/Tail). Set all Swashplate servos in middle Position and Tail Servo in middle position to mount the servo horn as near as possible to 90° degrees.
Re: Button in PC/Mac Software or JETI Setup
Posted: Tue 29. Sep 2020 22:17:12
That is already included. It is called Subtrim (tuning) menu.
Posted: Thu 01. Oct 2020 21:58:48
by yamahahoyt
Ok does it mean when I go in the Menu Subtrim all servos are in middle position (1520/760) and then I can mount the horns as good as possible and for the rest I use sub trim?
Posted: Sun 04. Oct 2020 19:30:20
Yes, if subtrim values are zero then it should be neutral position of the servos. For arms to be exactly in perpendicular position you have to change the values little bit.
This is purpose of the Subtrims.
