6 degree tuning value for a Flybar setup?
Fortune7
I'm setting-up a Raptor 50 flybar machine with a Spirit RS/Geolink combo. All seems straightforward but to get anything like 6 degrees pitch at the relevant part of setup, the slider value is way above the recommended range of 90-150. I need a value of 200 to achieve 6 degrees, with the blades in-line with the tail boom and the flybar perpendicular to the mainshaft. It's an easy-enough setting to make with a flybarless head, but can someone confirm the same technique is needed for a flybar heli, please?
Cheers, Andy
with flybar model you can set also lower value without any problem.
Maximally it will be only less stable.
So for the beginning you can set 100.
Fortune7
ZeXx86 wrote:Hello,
Many thanks, Tomas, I'll start with 100.
So are you saying the greater the value the less stable? How will I experience this to know how to adjust please?
Many thanks,
Andy
