I have the following problem.
I use the Spirit Governor with a YGE 205 HVT.
The three speeds in the three banks are correct and the internal Gov also controls very well, but it has often happened when I fly at medium speed (bank 1) and I want to switch down to bank 0 during the flight, then the speed reacts no longer, it only works again after restarting. What could be the problem?
Spirit RS Governor
Hello Tomas, I have solved the problem.
I had entered my high speed with 80% regulator opening at the maximum speed in the governor menu. Now I have entered the maximum speed at 100%, re-taught the controller and now everything fits. You should read everything right at the beginning.
LG Gernot
LG Gernot
Greetings Gernot
