Spirit RS on Nitro/Telemetry ports
smokin3000gt
Hello, I am building a Nitro 580 with Spartan RS and JETI DS. The sensors I need are the RPM sensor, Tempurature sensor, and battery cell sensor. I have been able to get all 3 sensors working when I use the AUX for power and Signal wire in the EXT/RPM pins but no sensors work on the EXT1.
I am wondering if I can use Sat 1 port for the temp or any other sensor? I'm trying to cut down on wires and avoid Y-cables/expander ports if possible.
if it is Jeti RPM sensor then it is enough to change port type in the REX-RS settings.
smokin3000gt
Is it possible to plug any sensors into Sat 1 port?
No, SAT port is used only for ESC telemetry.
