Update from 3.1.10 to 3.2.0 for motor tail?
Kluftinger
I'm running a µSpirit with a motor tail.
Everything is working fine so far with the special firmware 3.1.10
Does the new 3.2.0 firmware include all the goodies for the motor tail from 3.1.10? :?:
horneteer
What goodies are in 3.1.10? I'm using 3.2.0 and my tail motor spins up even when throttle hold is on.
tomsl
Hi
I am using 3.2.0 and my tail motor does what it should!! (Trex 150)
official hacker distributor USA
www.hackermotors.us
horneteer
Thanks for the info - may be my setup then. Will take another look at throttle hold value. Can't think what else it could be (also on a Trex 150 but with non-standard escs).
Sent from my SM-G925F using Tapatalk
Kluftinger
horneteer
Thanks Kluftinger - I'm using a heli version of blheli in the tail esc but but don't think there's any settings that would cause the tail to spin up at full speed when throttle hold is on. It seems the uSpirit doesn't detect that throttle hold is on.
Sorry for derailing your thread!
I am afraid the problem is in configuration. You can simply try to connect a servo at the CH4 port and see what is really happening.
horneteer
Ok will go over everything again. What should the throttle value be on the monitor page when throttle hold is on? Mine shows -0. Should it be lower than that?
Kluftinger
@horneteer
My spektrum radio has a range from -100 to +100.
Throttle hold is at -130.
@ZeXx86
Does fw 3.2.0 include every changes of 3.1.10
