I see in the release notes that Hobbywing ESC temp is now ambient (as opposed to FET before?). However, temp readings appear the same (I was expecting much lower?), is there a new telemetry variable I need to use instead now?
Thanks!
v3.2.0 on Spirit 2 Hobbingwing ESC temperature question
there is no other telemetry variable. Temperature you can see should be correct.
Thank you. All appears good, looks like either the ESC or the Spirit itself sends a max value of 100 when the telemetry is connected, and I was checking this. During a flight, the actual temp value didn't go over about 48, and it would have been over 100 before the update. Thanks for making this change.
