What is the gear ratio in Governor used for?
toadiscoil
I was checking my setup and changes on the gear ratio did not modify the target RPM on the software. Then I read the manual and it says that the Max headspeed is used for the calculation. Sure enough, I changed my max headspeed and I got the value I was expecting at 80% throttle. I thought that was just a "do not exceed" RPM setting and that the sensing divisor and gear ratio would do the math. Can someone explain then how these values really work and how the math is done?
