Tail Gyro
Luv2fly2
Please help as I can not find where to adjust the tail gyro.
I have the Head gyro and rescue or acro.
I am switching from Axon and with it you have two gyro channels 1: for head 2: for tail
Is this not the case with Spirit?
tail gain is assigned to channel 5 by default and should work with the most radios out of the box.
It is enough to set the values in your radio.
What radio, what receiver and what connection do you use?
Luv2fly2
Got the tail, trying to find out where I tune the head gyro. I did get the bail out set up but still want to be able to adjust the head gyro.
cracked canopy
Luv2fly2 wrote:Got the tail, trying to find out where I tune the head gyro. I did get the bail out set up but still want to be able to adjust the head gyro.
You will find it In the Sensor Tab labeled Cyclic Gain.
