New version 3.2.0 and Geo Link 1.2.0
deon.vanvuuren
I have a Spirit pro and upgraded to version 3.2 from version 3.1
I also upgraded Geo Link to 1.2.0.
When I go to rescue settings and check altitude limit in the windows software although it's enabled I cannot change the min and max altitude.
The text boxes are greyed out..
Please switch to Bank 0. There is no difference in version 3.2.0.
deon.vanvuuren
Where do I change bank to 0 ?
Thanks...
At the bottom of the Spirit Settings. If Bank Switching is turned off, then this feature is disabled and you are always in Bank 0.
Other reason that could cause such issue is the window you are viewing is too small. So that not everything can be displayed properly there.
You can try to enlarge the window, some screens are smaller so this problem can occur.
deon.vanvuuren
Thanks, if I increase triggering acceleration does it mean the model needs to decent faster for it to be activated...
So, an example if decrease this setting it will activate rescue when descending slower ?
