Bluetooth module
ajbwn
Hi my Bluetooth module arrived today can anyone tell me how to connected it up as it does not come with any instructions.
I have used one in the past on a Brian but that was easy just 1 plug, the spirit module has 2 plugs and i would rather not connect them wrong and damage something,
Regards Alan
Hi
Instructions can be downloaded from eshop, there is downloaf section on BT page.
ajbwn
Hi i have connected as this shows, the blue light is flashing on the module i open the app on my android device and it shows the BT module i tap on connect and it says connecting then just keeps saying disconnected , it will not connect.
Regards Alan
Then cable in SYS position is probably oriented incorrectly or BT module is powered from different supply than the unit.
ajbwn
All sorted thanks, had it powered from a 2S lipo not the unit.
Regards Alan
Great, if you connect grounds together then it will work.
