[ Spirit Aero 1.5.1 released! ]
Check out the news about the Spirit Aero.
Version 1.5.1 was released!
What was changed and what is new?
  • Quick Flashing Process update:
    • Updated instructions in the Spirit Settings after Flashing process.
    • In case flashing will not start normally, the software will repeat the process.
  • Futaba SBUS enhancement:
    • Improved compatibility with some FrSky receivers.
  • Spektrum DSM2/X protocol:
    • Improved compatibility with some Spektrum DSM2/X satellites for easier binding process.
  • OpenTX integration:
    • Integration scripts were updated with support for all new parameters.
    • Added support for Czech language.
  • Flight Trim:
    • Trimming feature was updated to work with any settings.
Version 1.5.0 - ChangeLog:
  • Brand new Quick Flashing Process:
    • From now you can flash new firmwares more smoothly, faster and reliable.
    • Firmware flashing can take just 7 seconds!
    • Once flashed, new firmware will boot up instantly with no need for re-power.
    • All settings are preserved as usually.
    • New Flashing Procedure will take effect after 1.5.0 update. Then next updates will be much faster.
    • Incorrect firmware flashing is not possible anymore.
    • NOTE: Transition from older firmwares is the most important to complete properly.
    • NOTE: Make sure that your computer can flash firmwares properly prior this upgrade. This is required only for this update, since old flashing method is still used (only first time).
    • NOTE: We recommend for Mac OS X users to make this transition on a Windows or Linux computer due to known driver issues. After this update, updating with Mac will be perfectly safe.
    • NOTE: If you want to downgrade to an older version, it is possible to obtain old compatible version upon request. Original old firmwares will not work.
  • New easy Recovery mode:
    • In case that firmware flashing was interrupted for whatever reason, Spirit unit will boot up in recovery mode automatically.
    • You can finish the flashing once unit will start to blink with LED quickly.
    • Enter Recovery Mode when Status LED is blinking quickly, select firmware and just press the Flash button.
  • Completely new algorithms for Rescue and Stabilisation modes:
    • New version of revolutionary Sensor Fusion technology for completely all Spirit units is here!
    • Rescue and stabilisation modes were totally reworked from scratch.
    • It brings significant advancements in precision, reliability and flexibility.
    • Model can be powered up, transported and left at any attitude during or after initialization. Yet it has no impact at Rescue and Stabilisation precision.
    • Model can take off from an uneven surface without affecting Rescue and Stabilisation modes.
    • It can work reliably under the most demanding maneuvers and very harsh environment at the same time.
    • Suitable for all models.
  • New parameter Stabi Correction:
    • It enables additional corrections from a Motion Sensor for further precision improvement of the Rescue and Stabilisation modes.
    • For models with a high vibration level it is recommended to leave default settings. (Disabled)
    • Enables the most advanced Rescue and Stabilisation technology.
    • Located in the Advanced/Expert Settings window.
    • Feature is turned off by default.
  • New Vibration Level measurement:
    • Vibration Level telemetry value is calculated by a new algorithm from all axes.
    • Vibration Level is more precise and is corresponding exactly with a real vibrations of the model.
  • Updated Sensor data processing:
    • Improved Sensor Data processing allows better rejection of possible interferences from connected peripherals.
  • RPM Signal Processing:
    • RPM signal measurement should be more stable and reliable.
  • Support for Spektrum SRXL2:
    • Support for Spektrum SRXL2 satellites and receivers.
    • New SRXL2 adapters for wiring will be available in our E-Shop.
    • NOTE: Spektrum SRXL2 receiver wiring guide is available at the Wiki page.
  • New function F: Output to AUX2:
    • Spirit Pro, Spirit 2 users can assign special function F: Output to AUX2 to directly control the port with a free channel.
    • Spirit RS users can assign special function F: Output to AUX to directly control the port with a free channel.
  • Function F: Output to CH0 and AUX2:
    • Output at CH0 and AUX2 is controlled from the beginning even during initialization.
    • This can allow for example smooth control of the retractable gears.
  • Support for Spirit RS units:
    • Full support for brand new Spirit RS units.
    • Spirit RS introducing control board and telemetry receiver in a single rigid package!
    • Specifications:
      • Dimensions: 36.8 x 27.15 x 15.8 mm
      • Weight: 23 grams
      • Material: Aluminium alloy AL6061-T6
      • Input Vultage: 3.5V - 12V
      • Sensor: 12-Axis Sensor Fusion
      • Processor: 32bit high performance ARM
    • Units are already available for order.
    • More information will be available at Spirit System information channels.
  • Futaba SBUS/SBUS2 enhancement:
    • Each data frame is examined to match correct time synchronization.
    • Additional protection from corrupted packets.
  • Support for three SRXL2 satellites:
    • From now Spirit 2, Spirit RS, Spirit Pro and µSpirit units can be interfaced with additional satellites.
    • You can connect them at the satellite ports with SRXL2-satellite adapter.
    • NOTE: We still recommend to use full size receiver + satellite receiver together.
  • Improved Spektrum Integration:
    • Entering and closing the Integration menu is now more intuitive.
    • Only once menu is completely closed with sticks, you will see CLOSED label.
    • During closing you will see CLOSING label.
  • Improved detection of SPM4649T receiver:
    • Receiver is now detected properly so that integration should work always well with all Spektrum radios.
    • Spektrum satellites are switched faster on signal loss.
    • Temporal signal loss during satellite switch is only 100ms long.
  • JETI telemetry tweak:
    • S RPM parameter has RPM extension after value.
    • This can be usefull for voice speech output.
  • HobbyWing ESC telemetry:
    • Temperature will corelate with ambient ESC temperature now.
  • Spirit Settings - Messages:
    • Spirit Settings software will let you know what is needed to do in unusual scenarios (Version Mismatch, Updating)
  • Spirit Settings - Log Viewer:
    • Fixed problem with a non standard Documents directory location.
    • Logs should always open whenever Documents directory is located.
  • Spirit Settings - In-Flight Vibration Analysis:
    • Vibration Analysis can be selected for any Special Function.
    • Previously only first 3 Special Function assignments allowed to see In-Flight option in the Analysis window.
No need to change any parameter after update from version 1.5.0.
WARNING: Update from 1.5.0 and older - Make sure that your computer can flash firmwares properly prior this upgrade. This is required only for this update, since old flashing method is still used (only first time).
WARNING: Update from 1.5.0 and older - We recommend for Mac OS X users to make this transition on a Windows or Linux computer due to known driver issues. After this update, updating with Mac will be perfectly safe.
Update for the Spirit units, OpenTX Integration is available in our Download section.
