Problem setup swashplate h4 / spirit pro
siberian
just tried to setup the spirit pro with the assistant. servos connected according to instruction (h4 90 degrees)
problems:
only ch 3 react to pitch (minimal servo travel)
only ch 1 react to aileron
see video
[youtube] https://youtu.be/U8H1VP8ulDg[/youtube]
how to solve the problems?
cheers
please set Swashplate type to CCPM 90 Velos, not CCPM 90.
siberian
problem is not solved with the velos setting.
Pitch: only CH 0 and CH 3 working
Aileron: only CH 1 working
Elevator: CH 0 and CH 2 working
Any new solution?
Cheers
I am afraid, but something is still wrong in the setup.
It is very important to set CCPM 90 Velos and save the settings.
Then all servos must move when you are moving with Pitch channel.
Can you verify that Pitch channel is moving in the Diagnostic tab, please?
