Throttle range with ppm
amfscy
I use the spirit with a jeti rsat (ppm).
Throttle range 0% - 100% in spirit diagnostic tab is different from 0% - 100% in my TX.
Is it possibe to use 0% - 100% from my TX or is it necessary to adjust the servo endpoints in TX?
First would be better for governor rpm calculation
For ESC it does not matter what do you see in your transmitter or the unit.
You should only recalibrate throttle range in your ESC, then it should work as supposed.
amfscy
ZeXx86 wrote:For ESC it does not matter what do you see in your transmitter or the unit.
Thank you very much for your fast reply.
