Goblin FIreball Havok Combo Telemetry available
Storchy
Is it possible to get telemetry values from the standard ESC HE022-S and if so, which ones,
Volt, RPM, Temperature?
I am using FrSky X12s
Thanks a lot
the ESC seems to be compatible with HobbyWing Platinum V4. So it should work.
You will need only Telem UNI cable and FrSky integration cable.
TheSteve
My Fireball Havok ESC had v-bar firmware installed - I had to flash it back to standard platinum V4 firmware for telemetry.
