Telemetry temperature issue Helijive / Spirit RS
Posted: Tue 19. Jan 2021 23:01:00
by Airjunkie
Hi, i use the Spirit RS (3.2.1) with a Jeti DS12 (3.2.0) and Telemetrie from the Helijive. This Setup works for mAh, V, A, Rpm nice and correct. But the value for Esc temperature shows during flight permanent 24 degrees. Sometimes appear Peaks up to 199 degrees and after that again 24. How can i solve this Problem?
Re: Telemetry temperature issue Helijive / Spirit RS
Posted: Wed 20. Jan 2021 21:22:53
Unfortunately the problem can't be probably resolved in any way.
Helijive telemetry protocol is undocumented, but it should be identical to Jive. The ESC is old and there are no firmware updates that could affect it as far as we know.
The only solution would be to ask Kontronik if they can provide any resources for Helijive protocol. We already tried it several times.
In our Jive telemetry guide we have no mentioned compatibility for Helijive for this reason.
On the other hand Jive Pro, Kosmik and Kolibri ESCs have fully documented telemetry protocol.
