Hi
I can't calibrate the Throttle Curve on the Hobbywing 60 V4 as in the manual discribed.
The Hobbywing should beep several times after plugging in power - but nothing.
I've an linear thottle curve in the jeti ds12 Gas from 0-100% stick is at 100% - Spirit RS bound - but the Hobbywing does not beep.
(Seems that the Spirit RS does not transmit the 100% gas stick position although the diagnostic-page in software shows the right gas stick position)
Any ideas whats wrong ?
Thank,
Matthias
[SOLVED] throttle calibration Hobbywing V4 with Spirit RS
it was always working for me with several Spirit RS's & different HW's, pls check if:
1. throttle channel (1?) is correctly set in channels setup
2. Spirit gov is deactivated during calibration (!)
3. throttle range is correctly set in Esc/Gov setup
cheers
Michael
Michael
