ADDING EXTRA CHANNELS ON DX 18 and 4651T SXL2 for geolink
cswhiting63
Thanks for all the help setup the unit works great. Flew today and was VERY COLD in NY but unit was awesome rescues work well inverted and upright return to home was great thanks love it. I have a quick question I have a DX 18 and 4651T which should let me access 20 Channels How do I add the extra 8 channels on the TX so I can assign more GEOLINK channels to control functions on the GEOLINK I have 10 avail now and used them up and I know if I add the X8 expansion unit it will work but Im not using that Im using new SXl2 tech I cant find it in the man prob simply thing Thank for your patience.
you can use 16 channels, but you have to re-bind receiver with 22ms framerate. Otherwise only 10 are available.
cswhiting63
Thanks that explains it I knew it was just a simple setting
cswhiting63
I got it to work thx but I cant not get the text gen option on the telem menu I have it set to roller s indicated have 2.07 airware any idea why it is not showing up in options?
