[ Version 3.2.2 released! ]
New version 3.2.2 released!
  • Brand new Online Updating Process:
    • From now all Spirit units can be updated online!
    • You can select which version you wish for update.
    • No need to download firmware files anymore.
    • User can't select a wrong firmware.
    • GeoLink firmware will be available for online update soon too.
    • Everything available from the Update tab in just two clicks.
  • JETI Integration enhancement - Bank Switching:
    • Bank Switching is working in Real-Time even when integration is active.
    • You can switch Banks directly with assigned switch.
    • By switching banks settings are saved immediately.
    • All parameters are displayed from selected bank.
  • JETI Integration enhancement - Subtrim Tuning:
    • Subtrims can be configured for all swashplate servos at the same time.
    • Collective Pitch can be changed in easy way when checking Collective Pitch Tuning.
  • JETI Integration enhancement - Servo Travel Correction:
    • Travel Correction can be configured for all swashplate servos at the same time.
    • Collective Pitch can be changed in Min. and Max. positions in easy way when checking Collective Pitch Tuning.
  • JETI telemetry - New ESC variables:
    • BEC Voltage is visible from the ESC itself - if supported by the ESC.
    • BEC Current is visible from the ESC itself - if supported by the ESC.
  • Spirit Settings software - Servo Travel Correction:
    • Collective Pitch can be changed in Min. and Max. positions in easy way when checking Pitch adjustment.
  • New Rescue - Smoothing factor parameter:
    • This parameter makes the Rescue engaging and disengaging transition as smooth as needed.
    • BEC Load can be reduced significantly in this way.
    • Default value is 0 - disabled - same as with previous versions. Max. smoothing factor is 10 which is great for a Scale helicopters.
    • Available in the Expert Settings.
  • New Rescue and Stabilisation precision improvement:
    • If you will encounter a precision problems after prolonged maneuvers, new Gyro Calibration method can be very useful.
    • This method is good in case that all other settings were not helpful.
    • If Wiki page has no solution for you, please contact us.
    • Gyro Calibration is needed only in very rare cases but can be extremely helpful for making Rescue absolutely precise.
    • Spirit System support will guide you with a further instructions.
    • Calibration can be also made in our factory for free. It is performed just once for unit.
No need to change any parameter after update from version 3.2.1.
Update for the Spirit units, JETI integration is available in our Download section.
WARNING: Update from 3.1.0 and older - Make sure that your computer can flash firmwares properly prior this upgrade. This is required only for this update, since old flashing method is still used (only first time).
WARNING: Update from 3.1.0 and older - We recommend for Mac OS X users to make this transition on a Windows or Linux computer due to known driver issues. After this update, updating with Mac will be perfectly safe.
Update 3.2.2 for the Wifi-Link modules is available in our Download section.
