Rescue setup on 3 position switch
Socal
Have a question on setting up rescue on DX-9 3 position switch on Trex 500. Have Acro enabled with 70% on position 0 and -70 on position 2 for rescue. Not sure what if anything I need to do to middle position 1? In diagnostic tab shows position 0 as HL, position 1 as HL, and position 2 as HF? Does this sound right?
Thank you all for your help in advance!!
welcome in our forum!
I recommend to set Gyro gain for position 1 too, because then, there will be 0% gain, so the rudder wont hold at all.
You can set same gyro gain as for position 0.
Socal
Great forum!
Is there a way to set that gain? I only have travel adjust for hi and low?
You can check this thread: http://spirit-system.com/phpBB3/viewtop ... f=20&t=448
Actually the result you want is probably very same.
Socal
Thank you.
