Align ESC RPM wire
rhmaddever
My Align ESC has a yellow RPM signal wire. Can this be plugged into the spirit?
Yes, you can plug it in. But wire must be moved at the middle pin in the servo connector.
rhmaddever
thanks. Which port should I use? Aux?
PIT pin as with any other RPM sensors, please see manual.
http://manual.spirit-system.com/index.p ... e=Governor
