My Spirit micro powered up in recovery mode today. When I use the PC to program it in recovery mode it will come to life, but after a reboot it will be stuck in recovery mode again.
It was fine last time I used it. It was running 3.2.2.
Spirit micro stuck in recovery mode - running 3.2.2(fixed!)
please read this thread:
http://spirit-system.com/phpBB3/viewtop ... =20&t=4521
It is very likely identical problem. We will prepare special firmware for you, then it can be fixed by flashing this firmware.
Please check the firmware and flash it to this particular unit. After flashing all should be fine and you can use normal 3.2.2 firmware again.
The software is ready for your unit, please verify it is visible in the Spirit Settings for you.
