[SOLVED] Spirit/Jeti/Gov
gerry
Hello Tomas!
I noticed an error with firmware 3.2.2 -r2. When I go to the governor settings with the Jetisender, I see all values at bank 0, OK. But when I switch the bank counter to bank 1 or 2 then it is The settings window is empty, no values can be seen. All values are available on all banks on the PC software.
Please check that, it would be very important because these values are different from the Gov on all banks, so you should be able to set them via the transmitter at the airport.
Greetings from Gernot
Greetings Gernot
please use scroll button to move up at the page.
Parameters are there, but other parameters are hidden, so they are just at different position, which might be not visible.
gerry
I hadn't thought of that, now everything is perfect.
Thank you very much for your tireless development over the years. It really has become the most perfect FBL system. Thank you for everything.
Greetings Gernot
