Spirit RS Governor
Posted: Tue 16. Feb 2021 20:14:46
by gerry
Hello Tomas, I use the internal governor with the Spirit Rs and am also very satisfied with the settings. The only thing that bothers me a bit is the torque in the first second when running up, which starts with a jolt, the rest of the run-up time then fits again. Is there a way to dampen the first jolt a bit? FW 3.2.2. Greetings from Gernot
Re: Spirit RS Governor
Posted: Tue 16. Feb 2021 20:26:53
by Habásek
Fine-Tuning – Spoolup rate
Configure speed of the motor spoolup. For initial tests we recommend Slow spoolup rate.
Fine-Tuning – Spoolup Rampup
Value that will be added at the beginning of motor spoolup – when Hold is turned off. If the spoolup is not smooth, i.e. motor will start with a kick, the value is too high. If the spoolup has a delay, the value is too low. Default value of 50 μs should work fine in the most cases.
http://manual.spirit-system.com/index.p ... e=Governor
Re: Spirit RS Gouverneur
Posted: Tue 16. Feb 2021 20:39:55
by gerry
Hello habasek. Thank you for your quick reply. I will deal with the two values in more detail. And adjust it even more finely. Everything else is going perfectly, I am very satisfied. Greetings Gernot
