3.2.2 uSpirit - Throttle "problem"
fassla
Current setup: uSpirit 3.2.2 // SRXL2 // NO Governer activated // NO bank switching activated
Observation:
Thottle is NOT follwing "regularily" the channel 1 from Transmitter.
See Documents attached - Thottle chanel is recognized correctly - Throttle OUT doesnot do so.
This is a crucial Hazzard, as Motor cannot be stopped !
4Blatt.4ds
(255 Bytes) Downloaded 118 times
uSpirit_SRXL2_Throttle.docx
(139.08 KiB) Downloaded 129 times
the problem is you have very low value (out of range) for throttle hold.
For this reason it can't work properly and even failsafe could trigger.
Please set value so that you will see 0 or -1% for Throttle Hold in your radio. Presently it is -19% or more which are invalid values.
Then everything will be OK.
