2 Spektrum Sattelits + external BEC
riodoro86
I would like to use the spirit fbl with two spektrum sattelits and I would also like to connect a BEC. Due to the wiring diagramm the BEC port is used by my second sattelite.
Can i connect the BEC to another port? Maybe Sys?
BEC or any other power supply can't be connected to SYS or ELE/PIT/AIL ports, else it can destroy the unit.
You can use Y-cable for this purpose, this can be connected to any other ports, so it will work fine.
The best is to use Y-cable in RUD position with second satellite.
Example: http://www.conrad.com/ce/de/product/208 ... bel-050-mm
