Stabilization mode
Posted: Thu 05. Feb 2015 9:32:08
just a small question about the stabilization mode. In the manual you have stated, that also the stabilization mode needs a negative gyro gain in order to be activated.
But why do I see a different behaviour on the ground with and without stabilization mode without a negative gyro gain? I have configured bank 0 without stabilization and rescue and bank 2 with stabilization.
If I tilt the helicopter in bank 0 the swashplate gets tilted but then returns to the normal position. In bank 2 the swashplate gets also tilted but then stays in this position until the heli is tilted back to the normal position.
Does that mean that the stabilisation is activated even without a negative gyro gain?
I don't really use the stabilization mode - it's just for interest.
Regards and many thanks
