Page 1 of 2
Blade 450x V2 mit SpiritRS
Posted: Wed 24. Mar 2021 11:56:43
by lifestyle
Hallo,
ich möchte einen Spirit RS am BLADE 450x V2 verwenden.
Der original Regler E-flite 35A Brushless-Regler, hat glaub ich keinen GOV Mode.
Muss ich dann den Gov im Spirit einstellen - oder geht das auch so mit den Gasgeraden?
Re: Blade 450x V2 mit SpiritRS
Posted: Wed 24. Mar 2021 12:25:54
by Mattes61
Hello !
For Govenormode you must have an ESC which is capable of govenormode - It doesn't work with the original ESC - buy an Hobbywing ESC or similar with an rpm-output . Then you can change between govenormode in the ESC or in the Spirit.
Best Regards
Matthias
Posted: Wed 24. Mar 2021 13:17:05
by lifestyle
Hallo,
mit dem original AR7200 BX FBL System hat der Heli auch funktioniert. Meine Frage war nur, wenn ich das AR7200BX gegen ein Spirit RS tausche,
ob das auch so einfach geht mit der Gasgeraden
Posted: Wed 24. Mar 2021 14:29:45
by swash23
ja, es geht auch nur mit einer Gasgeraden.
Posted: Wed 24. Mar 2021 14:42:18
by lifestyle
also mit dem original Regler - und im Spirit KEIN Gov. nutzen.
Vielen Dank.
Posted: Wed 24. Mar 2021 14:45:49
by swash23
ja
Posted: Wed 24. Mar 2021 14:55:38
by HeliMLM
of course this will work fine with this Esc too... but: as it does not have rpm signal, there is no way to use any external gov - that's the only downside. so there will be no RPM in Spirit/Jeti telemetry.
just connect E-Flite Esc to THR port on Spirit RS unit and set Throttle to channel #1 in Spirit settings tool. do NOT active the Spirit's gov.
Ciao
Michael
nb: ... and if (later) you really want Esc telemetry... just go for YGE 35LVT... this will give you a perfect Gov, full Esc telemtry for Jeti and programming the Esc from you Jeti Tx
Posted: Wed 24. Mar 2021 15:10:46
by Mattes61
yes it works also with an straight line, but this means not that you have a possibility of govenormode -The ESC posseses only Controller Mode (Steller-Modus) -
For govenor mode you need an ESC with rpm-output, something like Michael or I said -
Best Regards
Matthias
Posted: Wed 24. Mar 2021 15:25:09
by lifestyle
Kommt der stock ESC wirklich an den Eingang Drehzahl? "RPM"?
Beim Spirit RS ist das doch der Ausgang für den Regler "THR" ??? Oder liege ich da falsch?
Posted: Wed 24. Mar 2021 16:50:09
by HeliMLM
THR of course....
