Spirit RS and Jeti 900NG Sat backup doesn't work
heliflieger8587
the SpiritRS doesn't work with the Jeti 900NG Backup.
I have changed the EX1 Port on SpiritRS to EX-Data/Backup.
After this I have connected the 900NG SAT to the EX1 Port and bind them.
Both RF Modules are bound with the receivers.
After disable the main TX in the transmitter the SpiritRS goes into failsave and in the RF menu the receiver and the RS are not available anymore.
So the Backup doesn't work with the SpiritRS.
What must I do to get this working?
Bjoern
heliflieger8587
I have now tested the RSat 900NG in combination with an REX3.
This combination works fine.
So there is a problem in the SpiritRS.
Could you please help.
have you configured REX3 port in the same way as REX-RS?
Is there some difference? We will consult the problem with JETI.
heliflieger8587
Yes, same options.
Rex3 Configured as "EX Bus Input/Backup" same as in SpiritRS
RSat is configured with "EX Bus"
