Help! Cannot save "Rescue Collective Pitch" setting
mgrezmer
Just received my new Red Jeti DS-12 and Spirit RS combo last month and finally have it flying my heli. It flies great. Really great with almost no setup adjustments required.
Problem is it will not save the RCP setting I want to change. Every thing else works fine.
What is going on? The whole system is brand new.
Really loving to be able to do the entire setup from the TX.
it could be enough to update the BIN file.
Please download the file from our download section.
https://spirit-system.com/dl/jeti/SPIRIT-3-2-2.zip
Then replace the old version with this new.
Please see instructions here:
http://manual.spirit-system.com/index.p ... N.29_files
mgrezmer
mgrezmer
Have updated TX bin files to v 3.2.2 per instructions. Still could not save the "Rescue Collective Pitch" setting from the Jeti ds-12 spirit integration menu. Am setting it to 75, pressing OK and then backing out to where I save the settings... I then turn off Spirt RS and TX. Upon starting the TX and Spirit RS back up, the "Rescue Collective Pitch" defaults back to 100.
TX integration version: 3.2.2
Spirit RS version: 3.2.1
Note, when trying to update firmware for spirit rs from spirit settings software on PC (v3.2.2) it says there are no updates available and I don't see the firmware available from the download site anymore.
Thoughts?
mgrezmer
Also, I am wondering if there is a way to confirm, within the jeti ds-12 spirit integration software, that it has been updated to v 3.2.2 other than having copied the bin files per instructions. I see firmware in the tx as 3.2.1 and am assuming that is for the spirit rs.
Thanks in advance for your help.
latjo-k
mgrezmer wrote:Also, I am wondering if there is a way to confirm, within the jeti ds-12 spirit integration software, that it has been updated to v 3.2.2 other than having copied the bin files per instructions. I see firmware in the tx as 3.2.1 and am assuming that is for the spirit rs.
Hi
To be sure delet the 2 Spirit files and the mapp in TX,then copy new ones.
//Latjo
mgrezmer
As of this morning I was able to update my Spirit RS to 3.2.2 using the PC/USB connection.
I am still unable to change the "Rescue Collective Pitch" value and have it save using either the TX or the PC/USB.
