Spektrum Receiver AR8000 PWM connection
Hififreak
Hallo,
i build my first Heli (KDS Chase 360), at first i take the AR610 but i change to the Spektrum AR8000 Receiver and i need the PWM connection from Hobbywing Platinum 50 to Ar8000 and from AR8000 to the Spirit.
i have the Spektrum DX6 Black edition
Sorry i am a beginner
Regards Ritchy
Hififreak
i can make what i want, but it does´t works.
I take the ar610 and ar8000
can you describe what does not work?
Make sure that PWM receiver type is configured in the software.
Hififreak
The connect from the receiver to the spirit doesn't work
I test the receiver, i take the servos into the receiver and there are works.
But not with the Spirit.
Your manual in english is to deferent to the in german.
I think the mistake is when i bind the system, but i can't find the correct way
OK, please can you take a photo of your connection?
This can be much faster to determine where is the problem.
Hififreak
when i change to PWm the rud works, but the other ones not
but this is not Spektrum DXms2 with satellites
did i need the spektrum adapter for the ar 8000
but i test with the ar610 there are the thame problem
You should set connection type to PWM if it is normal receiver connected with three cables that are included in the box of the unit.
Hififreak
i have a SPEKTRUM DSM2/X SATELLIT recever, the protocol are DSMX
It does not matter which satellite you are using, if you want to use AR8000 (+ satellite) it must be always PWM connection type.
