Jeti DS12 stick deadband with function channel (Spirit RS)
marcothefly
Hi, I have paired the SB stick on the DS12 with the function channel stick deadband .
In position of it gives a value of 17 while in on ,30. On the bank, for example, I have a value of 6. When I turn on the TX , the value that previously was 6 is now 17. I don't understand what 17 hits and why it doesn't have a scale from 2 to 30 as the deadband set on the Spirit settings.
Has anyone already tried to make these settings?
Thank you
it is using range from 2 - 30. 2 = 0% and 30 = 100% channel value. So your assigned channel has value somewhere in the middle.
You can verify it in the Channels tab.
