[SOLVED] Jeti Integration Saving Bank Parameters
Shrekno1
I have noticed some strange things when configuring the Spirit through Jeti integrations, specifically when making specific bank changes.
I give you and example, when I go to change the gov settings I have 3 columns where I can set individual settings for each bank. If I enable the gov for bank 1 and bank 2, save the setting to the unit and reboot the fbl my settings are not saved.
It all seems very strange, can someone point me in the right direction and explain what I maybe doing wrong? I have the most recent Jeti integration file install on the transmitter and on the lastest firmware on the spirit pro.
Thanks.
Steve
please update BIN file and firmware in the Spirit unit to the latest one.
There were changes in the JETI integration with banks that require very latest files on both sides.
I believe this will help.
Shrekno1
Thanks for that, I swear I had installed the most recent Jeti files but obviously not as it works perfectly now.
Steve
