[SOLVED] Collective pitch not working
Fred Loo
Hi Support, I need help as to why my collective pitch does not move at all.
I use futaba Sbus as receiver on micro spirit fbl. I did all mapping and found to be correct. Is there any other cables I need to use?
Thank you.
Please help
Fred
does it work in the Diagnostic tab?
With Futaba SBUS wiring all the channel mapping should stay unchanged.
If collective pitch is moving in the Diagnostic tab then it mean you have enabled Rescue mode and it is active all the time. It is enough to disengage by assigned switch or gyro gain.
You can see all this in the Diagnostic tab. If Gain will be positive, it will disengage the rescue and collective pitch can move.
Fred Loo
ZeXx86 wrote:Hello,
Thank you for your instruction. Yes, you are correct. I made the changes. It caused rescue mode due to previous had set rescue mode earlier.
Thank you again.
