Page 1 of 2
[SOLVED] Spirit 2 - servos slow to return to centre
Posted: Wed 12. May 2021 11:50:07
by Nmony
I have 2 Spirit systems, a Pro in a Goblin 500 and a Spirit 2 in an old TT Raptor 30.
Spirit 2 in the Raptor is behaving strangely, i have Align DS615 servos and the settings for Pulse & Frequency are set correctly but when I push the Elevator or Aileron on the TX it takes 3 seconds for the Swash to return to centre - heli is on the ground, engine not running.
Swash correction is working fine.
I have enabled the flybar mechaninc in the settings - makes no difference.
When I go into servo setup then the servos snap back to centre as expected.
My Goblin & Spirit Pro do not behave in this way.
What am I doing wrong?
Re: Spirit 2 - servos slow to return to centre
Posted: Wed 12. May 2021 12:05:16
by vvv850
I don't think you're doing anything wrong. This is how it behaves on the ground. It's called bench mode.
Posted: Wed 12. May 2021 12:57:16
by Nmony
vvv850 wrote:I don't think you're doing anything wrong. This is how it behaves on the ground. It's called bench mode.
Is this part of new firmware?
Strange how my goblin does not do this
Posted: Wed 12. May 2021 15:18:42
by vvv850
Check here:
https://www.spirit-system.com/phpBB3/vi ... nch#p34144
I'm not sure when this behavior has been implemented.
Posted: Wed 12. May 2021 16:31:45
by Nmony
Had a look at that but it does not seem to improve things - I'll create a video to demonstrate.
Posted: Wed 12. May 2021 17:19:21
by vvv850
I believe there's nothing to improve. I just wanted to show you that this is a bench behavior.
Posting a video would be helpful and I can compare with mine.
Cheers
Posted: Wed 12. May 2021 21:17:12
maybe there is a fan which is making a vibrations that are pushing the unit in flight mode.
While other units are not affected and gyro sensor is not sensing any motion.
Anyway this is not an issue at all. It is perfectly correct.
Posted: Thu 13. May 2021 6:30:23
by Nmony
ZeXx86 wrote:Hello,
Is this something new in the firmware ?
Why is it doing it?
Is there a reference to it in the manual?
Posted: Thu 13. May 2021 10:35:24
by Nmony
here is my Goblin - it is behaving the same as the Raptor now:
https://www.youtube.com/watch?v=X7owW9Fu6qo
Posted: Thu 13. May 2021 18:38:08
by buttles
On the bench that's exactly how it should be. If both units are doing it then you have two perfectly good Helis!
Do they fly well??
