Unable to see data-log using Wifi-link on phone (Android)
TomazBernik
Hi, I have problem: when i want to see a flight log under "diagnostics" tab on my Android smartphone, I'm asked to choose Storage directory to save my log, but when I tap on that, the Wifi-link disconnects and that's it...I can only go reconnect and start over to no avail.
All other stuff - all unit settings and also vibration analysis & bec tester seems to be working properly with Wifi-link & android system.
Wifi-link wiring connections to the FBL units are made as per manual instructions.
My units are Spirit 2.
The firmware I run on them is v3.2.1
The android app "Spirit settings" is v3.2.0
Ideas please!
Frigetrus
I have the same problem. Can't change directory, and the wifi link disconnects every time when I try it... :(
Jeti DS12, Align T-Rex 470L with Spirit GTR, Soxos Strike 7 with Spirit GTR
TomazBernik
So this one really looks like a bug. I've also tried it using my wife's phone and result is the same. When I tap to choose directory to save logs, it just disconnects.
So Tomas, can this issue be looked into please?
it is needed to allow storage access in the Android settings. So then it will be able to access the directory and you can choose it.
TomazBernik
It works. Thank you!
