Only partial stick range when set Cyclic Ring limit
Aquaaddict
When Cyclic Ring is set to limit around 10 deg and prevent binding, then only about the middle 50% of my cyclic stick movement is active. E.g. if I move the stick to the right then the swashplate reaches the 10 deg limit when the stick is about halfway between centre and the edge, so the remaining travel of the stick to the edge has no effect, so all 10deg of my cyclic control is concentrated in half of the stick movement. I have found this on both helis I have installed Spirit on, both helis are setup as per the manuals with respect to servo arm length, and mechanical setup has been done (subtrim set level, swashplate levelled etc) so I am guessing this an indication of setup issue somewhere?
The Tx full stick movements result in 100% shown in Diagnostic tab, so Tx endpoints are correct.
How do I get 10 deg of swash travel over the full range of stick movement instead of just the middle 50% of stick movement?
Ants
