Firmware
Posted: Fri 21. May 2021 16:50:12
by sparts
Where do I find the firmware to update my Spirit Pro to 3.2 ? It is currently showing 3.1.0.
Re: Firmware
Posted: Fri 21. May 2021 18:32:55
by Swetommy
I have the same problem.
New to Spirit systems and trying to update my new Spirit rs from 3.1 to 3.2.2 but cant find version 3.2 anywhere..
Re: Firmware
Posted: Fri 21. May 2021 19:14:07
by 10x
Just go into Spirit settings software and update and it will automatically find the latest...
Re: Firmware
Posted: Fri 21. May 2021 19:54:16
by Swetommy
The spirit setting software tells me that firmaware 3.1 is not compatible with Spirit settings 3.2.2 and i need to update the firmware.
But in update tab it says No awailable firmware..
Re: Firmware
Posted: Fri 21. May 2021 20:22:42
by sparts
Exactly same as me
Re: Firmware
Posted: Sat 22. May 2021 6:41:34
by Swetommy
Now it works :D
just updated firmware sucsessfully.
my guess is that something on spirit“s end was down.
Re: Firmware
Posted: Sat 22. May 2021 8:06:00
by sparts
Where did you find the firmware link
Re: Firmware
Posted: Sat 22. May 2021 11:44:17
by buttles
In the good ole days, before 3.2.2 the firmware and 'pc' software were downloaded manually and then nailed together.
Now all you need to do is run the 'pc' software and the program SHOULD find the correct firmware. There have been a few threads on this and there may have been a few teething problems with some people's setups.
Tomas should be along to help out.......
Re: Firmware
Posted: Sat 22. May 2021 12:04:37
by Swetommy
I connected to spirit settings and now there was
Firmware updates in the update tab.
Re: Firmware
Posted: Sat 22. May 2021 21:15:13
by sparts
It's back to working again, all flashed.
Thanks for the input chaps
