Battery Backup
Dr.Fleming
Hi Tomas, why you not offer a Battery Backup System! I try the Optipower the Scorpion all this was
shit. now I'm thinking to connect a 2S Directly to the Spirit, but I like to make some switch and fuse to it,
what you think!
latjo-k
Hi why not use one of this?
https://www.helistore.se/produkt/1st954 ... 4-8-3x50f/
//Latjo
HeliMLM
... exactly THE solution ;) you do not have to care about it anymore after installation...
cheers
Michael
latjo-k
HeliMLM wrote:... exactly THE solution ;) you do not have to care about it anymore after installation...
I have set the YGE bec to 8V and the alarm in TX (Jeti) to x<7V.That gives me abaout 1,5min to land when the
alarm goes on.
//Latjo
Dr.Fleming
latjo-k wrote:Hi why not use one of this?
//Latjo
And what about the reverse current ! :cry:
HeliMLM
depends on your Esc if the reverse current is a problem... the buffer is great: peaks are handled, servo back emf is heavily reduced. with i.e. YGE there is no problem with buffering. if it is a problem with your Esc, there are possibilities to block the reverse current.
cheers
Michael
Dr.Fleming
HeliMLM wrote:depends on your Esc if the reverse current is a problem... the buffer is great: peaks are handles, servo back emf is heavily reduced. with i.e. YGE there is no problem with buffering. if it is a problem with your Esc, there are possibilities to block the reverse current.
Will Test it, thanks. ;)
