[SOLVED] telem uni cable homemade
Posted: Mon 07. Jun 2021 7:21:17
by Anton38357
Should be a quick one to answer...
Just bought a few things from the online Spirit FBL shop and forgot to add the Telem Uni Cable :(
Can a normal JST-RX adaptor still be used with the Spirit Pro and Spirit V2 just with the red (middle) cable removed?
Hope to hear from someone..
Re: telem uni cable homemade
Posted: Tue 08. Jun 2021 21:29:42
Yes, you are right.
Red wire disconnected. Otherwise it could burn unit.
Posted: Sat 03. Jul 2021 11:40:44
by azaz44
Having same problem here. I'm switching the ESC and just need Telem Uni. Did it work for you Anton?
What is then a difference? Telem Uni seem to have some PCB inside, so is it not needed at all?
Posted: Mon 05. Jul 2021 7:56:42
by Anton38357
Nope, you don’t need the bought one. Home made works perfectly fine.
It looks like a pc board, however just a 3 in, two out.
Recap, just snip the positive wire - all good.
Re: [SOLVED] telem uni cable homemade
Posted: Thu 15. Jul 2021 22:32:41
by azaz44
Thanks, I did it and it works fine.
