Spektrum SRXL2 and DSMX
Anton38357
Tried searching this forum and the web quite a lot, however could not find the answer..
If I use the Spektrum SRXL2 receiver(s), AR6610T or 4651T - can I still use one or two DSMX satellites AND will full telemetry still work if setup as per the guideline manual?
Hope to hear from someone that has successfully done this and could maybe post a quick rundown on how it was conducted.
unfortunately this is not possible.
Only if you will use SRXL2 receiver with embedded Spektrum satellite port.
Anton38357
Thanks heaps for the reply!
"Only if you will use SRXL2 receiver with embedded Spektrum satellite port" - does this mean SRXL2 satellite receiver into the side port with the adapter cable?
Example - An SRXL2 receiver (AR6610T or 4651T) are used in the E/P/A and Rudder as per the manual (main receiver). Additional SRXL (4651T / 9747) satellite(s) could be used in the side port and full telemetry will remain through the main receiver? Additional receiver(s) connected with the Spektrum SRXL2 Satellite adapter cable.
Is this correct?
yes, you are perfectly right.
But in this case connecting additional SRXL2 satellite receiver directly to AR6610T is recommended, because it has slot dedicated for this purpose.
But your wiring description will also work.
10x
You can use the 6610t pluged into the Spirit with the 4651t pluged into the 6610t not using the sat port...With this combo you need to plug spirit to 6610t wire into port 1
of the 6610t and not data port....
Anton38357
Thanks for the confirmation :)
Reason why I was asking is because I was thinking either by doing it two ways:
a: 6610T and a SPM9747 (SRXL2 remote Satellite without telemetry) as an extra receiver. The 6610T is already telemetry enabled so a 4651T will be a waste - double the price instead of a 9747 here in OZ
b: 4651T as the main receiver in port one and an additional 9747 (SRXL2) in the side port.
Both ways above keeps everything SRXL2 protocol.
Happy flying...
