Setup:
ESC: YGE95 LVT + Adapter to the SAT1 port
Motor: Kontronik Pyro 600-9 with 930kV
FBL: Spirit 2
RX: Spektrum 8020T
Servo: GDW BLS89HV + BLS805X
With the above setup (throttle on RX) I don’t get any reading of rpm in the ESC window of the telemetry.
If I connect the data wire of the YGE via TexY-adapter direct to the Xbus of the RX w/o power up the Spirit, I have a rpm reading in the telemetry. This means the YGE alone is working fine.
With the Xbus still active, there is no telemetry at all, when I power up the Spirit. Is that correct ore should the telemetry still be shown ?
I have also put the numbers of poles and the gear ratio in the governor setup of the spirit, even if the throttle wire is connected to the RX.
I changed to a Hobbywing 80A v4 ESC and there is a rpm reading, BUT no current data.
When I add the Blades and run the heli on the ground, there are some numbers for current popping up, but no constant reading.
I’m not sure if the current is still too low for the HW ESC to show them on the screen.
For both ESC’s the adjustment in the Spirit telemetry window did match the ESC.
An intensive online research didn't deliver any hint.
What else can I do to get a rpm reading with the preferred YGE controller??
