Spirit GT , Stern adjustment
NitroRex
Do the rear blades with GT have to have a lead of approx. 3 ° if the linkage is 90 °, or do they have to be neutral?
Normal mode and HH mode?
it is same for all Spirit units. They should be ideally in 3-4° while servo arm is at 90°. Head Lock mode is used by the most pilots.
buttles
Hi Tomas, can you check the 'Servos' page in the manual as it says 90 deg for horn and 0 deg for blades. This came up a while ago but wasn't sorted. Thanks
