Settings 3.3.0 MAC-version & Recovery
ajadda
I had a fail while updating to Firmware 3.3.0 with a black Spirit via WiFi, so I had to do a recovery. However recovery did not work with settings 3.3.0, neither via WiFi nor USB cable. So I used settings 3.2.2 which worked in recovery mode via USB cable.
The same happened again today while updating to FW 3.3.1 with the same black Spirit and recovery did not work with settings 3.3.0, but did work with settings 3.2.2, even via WiFi.
Did someone else have this problem or was it just accidental? Or could this be related to this special black Spirit unit?
All my other different units had no problems updating to FW 3.3.0 and 3.3.1.
Regards,
Alexander
larghio
wifi upgrade failed with linux client 3.3.0
linux client 3.3.0 segfaults when recovery is attempted
3.2.x recovery works
Thank you for your message. We will try to find where the problem is, because it is working perfectly for us on Mac, Linux and Windows with all units.
I am sure we will find the problem, hopefuly today.
