Spektrum Multi adapter - sat stuck in bind mode
Posted: Thu 01. Jul 2021 16:35:43
by indeva
I'm using a Spektrum SRXL2 telemetry receiver (4651T) with two DSMX satellite receivers. I bound all three to the radio prior to installation. Now when using the Spirit Spektrum Multi Adapter plugged into the Spirit 2 RUD port and AIL pin as directed, the left side of the adapter that connects to the sats is putting that sat in bind mode. The right side of the adapter works fine. If I swap the two sats, same thing the left side of the adapter always puts the sat in bind mode. In the Spirit Setting software I have the receiver setting set to SRXL2.
Do I need to change something in the software settings, or is this a hardware issue with the Spirit Spektrum Multi Adapter?
