Activating Auto Bail Out on the Spirit GT with Jeti
krm97
I just got a Spirit GT and set it up to the recommended software settings for an Oxy 5. It flies great.
I also have a Jeti DS 12 with accelerometers and wish to set up the auto bail out function on the Spirit GT. I followed all the instructions in the software servo assignment page and used channel 7 for the auto bail out function. I set the accelerometer Y Axis to channel 7 and registers on the Spirit software when I move the transmitter upwards but the swash plate does not move up.
My question is, how do I get the Auto Bail Out function on the Spirit GT to work on the Jeti DS 12 with accelerometer function enabled?
Also, we need the Jeti 3.31 integration software for the Jeti transmitter. When will it be released?
All the best,
Ken
the procedure is very same as engaging any other Rescue mode.
The only difference is you need to set Stabi - Function to Rescue (Automatic).
Please attach your settings 4ds file so I can check if it is all OK.
krm97
Thanks for the quick response. Attached is the Spirit settings that you requested.
All the best,
Ken
Spirit oxy5 meg.4ds
(255 Bytes) Downloaded 71 times
