[SOLVED] Mechanical Mixing
FlyboyPeter
Hi People
Can the Spriit be used with a heli with mechanical mixing, had a good look at the manual and it does not appear to support mech mixing, but I could be wrong.
Was looking to fit one to a Raptor...
best regards
Pete
you can set CCPM 90/120/135/140° and also set cyclic phase angle for multirotor heads.
What Raptor do you fly?
FlyboyPeter
Hi and Thanks for the reply.
It is the old raptor 50 Se.
I assume that 90 deg is for the mech mixing. ( ie seperate pitch/roll/elevator servos).
best regards
Peewee
FlyboyPeter
Hi people
Can anyone tell me if I can use the Spirit on a mech mixed swash like a Raptor.
Best regards
PETE
Spirit support 90° mechanical mix. It should work with 3 cyclic servos and rudder servo.
FlyboyPeter
Thanks for the great support
Buying shortly
Best regards
Pete
