[SOLVED] Coaxial mode - limited pitch
Nmony
I am uing Bank swtiching to set Stabi - Coaxial on my Goblin 500.
When in Bank 0 I am set up for 10 degrees of pitch, pos/neg.
When I select Bank 1 = Coaxial Stabi, then the pitch jumps to 5 degrees of Positive pitch if i am full pitch.
Anyone have a clue what setting I need to change to fix this or is this expective behaviour?
it is enough to set Collective Pitch Range in the Limits tab to the same value as for Bank 0. Then it will work.
Nmony
ZeXx86 wrote:Hello,
Thanks so much!
Issue is resolveds 8-)
