[SOLVED] Spirit 2 not initilizing in 3.3.1 after upgrade
Jojo
I have upgraded firmware on my Spirit 2 with latest and it doesn't anymore start up normally.
Goes into Blue Led blinking mode and i can't anymore connect via USB nor via Jeti TX.
Only if i flash again same firmware it works, but if power off Spirit , it doesn't initiate when i power it up.
Tried the old firmware but same issue, i have never had this issue with any spirit modules.
Can i get help to fix this?
please send .spirit-flash.cfg file to a private message or our email. With this file we will be able to fix the problem.
I will send you all instructions.
Jojo
Its sent via PM
ZeXx86 wrote:Hello,
Moki38
Same here, Same Spirit2, Same firmware, same result -> Bricked Spirit2
Did a search for the file (.spirit-flash.cfg), can't find it..(W10).
But i have multiple units, does it get overwritten?
The issue was resolved after our private conversation with special firmware. We recommend to use the latest Spirit Settings for updating the units.
